1972 16’ Jon John Double-Wide Boat for Sale in Wilmington, North Carolina
  • Thread starter SandroJr
2K Total Thread Views
SandroJr
16’ JON JOHN DOUBLE-WIDE BOAT 1972 VINTAGE MON ARK 1652 TOTALLY RENOVATED WITH MOTOR & TRAILER & MANY EXTRAS
Includes motor, trailer, and many, many extras. See accessories list below for just about everything you could possibly need. Clean titles for everything. Selling it because I have a bad back.
It came from the Triangle and probably has never been in saltwater.
Came from an old friend that literally had not used it in 15 years.
Unique commercial model, that was made to better specs. They really do not make them like it anymore.
I have spent over $2,200 just in materials/parts and over 360 hours in renovations over the past two years.
I am very meticulous with my work. You will have a boat that needs nothing, I repeat, no repairs or maintenance to do.
Firm price, cash only, serious buyer only please.
Boat Features:
Has flotation material under the bow, all decking, and aft bench seat.
Reinforced beams across/under bow platform.
Coast Guard compliant navigation lights and accessories.
Full beam width livewell.
Oar brackets.
Reinforced side brackets near aft.
Bow mounted marine stereo speakers.
Cleats on bow and transom corners
Accessory locked storage box
Sealed battery box
Eye rings on both sides
Remote-controlled stereo with USB & Bluetooth
Boat Specs.:
1972 Mon Ark Commercial 1652
Approx. weight: 400 lbs. (with motor)
Beam: 73”
Side depth: 20”
Max. horsepower: 50HP (35HP, before modifications)
Bow: Upswept V
Transom: 20”
Weight capacity: 1100
Persons capacity: 5/700lbs.
Boat Work Completed:
Reinforced bow eye with thick plates
Reinforced transom & transom support bar
Replaced transom interior wall with treated beams and new hdwe.
Stripped hull & applied two coats paint
Replaced all decking with 1/2” treated painted (both sides) plywood. Used almost 600 screws, placed 2” apart.
Outboard Motor Work Completed:
1986 Mercury 25HP long-shaft tiller four-stroke with new electric start kit
The motor has very low hours on it.
Just completed spark plug replacement, tune-up & maintenance
Just installed water pump rebuild kit
Just rebuilt carburetor and replaced float
Just replaced fuel filter and internal fuel line
Just replaced rod retention clips
Just replaced gearcase oil. Bearing carrier seals checked OK.
Installed lanyard kill-switch
Trailer Features/Work Completed:
1971 steel, unique, pivoting, tilt-trailer for easier loading & unloading.
Previously replaced tires (5.30-12), only 150 miles on them.
5 stud rims
Manual winch
Mid-frame and stop lights
Rubber side-guard rollers
Spare tire mount
Replaced all bunks & re-carpeted
Replaced bow stop-roller
Replaced hub bearings(1”)/races/seals/bearing buddy protective caps
Replaced front section of trailer with a solid beam.
Electric System Work Completed:
All wire installed in sealed electric conduit
All connections were soldered and covered with silicone
8Ga. Wire for 30A quick-connect at bow for 30lbs. thrust trolling motor
30A gold-plated circuit breaker for trolling motor circuit
100A stainless steel six circuit enclosed fuse panel
All grounds connected to gold-plated wiring block to prevent electrolysis
Bow and transom LED navigation lights.
Stern light
Bow accessory power connection
Storage box with three accessory power connections
Four marine switches to control all circuits separately
Quick-disconnect battery terminal
Green LED night fishing/entertainment lighting
Accessories That Are Included:
6Gal. fuel tank (new fuel line, primer, fuel connector, vented cap)
Aerator for well
Anchor
Fishfinder (can be mounted on top of storage box)
Extra propeller
Two ratchet retention straps for securing it when trailering.
Heavy-duty trailering boat cover with engine cover, strapping, and stationary PVC upright storage supports.
Throwable Type IV flotation device and a life jacket.
Flashlight
Whistle
Signal mirror
Portable VHF radio
Fire extinguisher
Three fold-down seats. The third seat can be mounted on the livingwell bench seat, or wherever you it mounted.
I have new outdoor carpet, if you want it for installation on the bow or a bench.
External FM radio antenna
Oar horns
Mooring lines
Drain plug
800CCA heavy-duty deep-cycle marine battery
Mon Ark
Commercial 1652
$3,600
Wilmington
North Carolina - NC
· This item is being sold by ONLINE AUCTION on... Homer, Alaska - AK 99603
  • bondy
· HELLO, this STARCRAFT boat has very nice... Seneca, South Carolina - SC 29672 · Price: $3199.00
bondy
  • Bevie
· I have a 2010 Polar Kraft jon boat for sale... Jupiter, Florida - FL 33469 · Price: 950
Bevie
