Restored Thundercraft Bowrider Excellent Condition - Mercruiser Engine & Sterndrive
  • Thread starter Thread starter Amy Potthoff
2K Total Thread Views
Amy Potthoff
CALL 863-594-7237 to see this boat today!
This boat is ready for the water today! Clean boat title. 16ft single axle trailer is also registered and ready for transfer. Restored! 1988 16ft Thundercraft leisure bow rider power boat. Comes with a full tank of gasoline! Priced to sell! Available today! Call for a sea trial.
This leisure boat gives a solid smooth ride. The Mercruiser inboard motor is smooth running and moves the boat with ease. Boat is in excellent condition and has been carefully restored with new marine vinyl and outdoor rated carpeting. High quality foam cushioning, Stainless steel screws and bolts, pressure treated exterior grade wood and marine plywood with fiberglass coat where needed. Clean waxed, polished and detailed.
Features include custom control panel with new wiring and gauge set including quad gauge for fuel, oil pressure, temperature, battery level. New trim gauge with sender, digital GPS guided speedometer for accuracy custom control panel, depth finder alarm, compass and new switches, fuses and fuse holders. 5V USB charging station, 12 volt DC port for charging phone or accessories. New stainless steel steering wheel.
New captains chairs and stands with variable height adjustment add to a comfort ride. Bow of boat has storage under seating and built in live well/ice well with drain. Fire extinguisher, boat anchor with rope, ski tow rope, boat cover and tie downs are included.
Engine is in good condition and recently serviced to include rebuilt marine carburetor, New fuel lines, clean gas tank. Clean electrical connections, new wiring with marine connectors where needed. New marine alternator, oil change, fuel filters, new marine starter battery, marine starter and starter coil. Trim motor is fully operational. Navigational lighting is operational.
Alpha One stern drive also has been serviced to include: new propeller, drive shaft alignment, new drive bellows, exhaust bellows, and shift bellows, rubber seals where necessary, new water impellor pump. Gear lubrication and drive inspected. New shift cable and adjustment.
Trailer is in good condition. Trailer winch has been lubricated, wiring connections have been cleaned and soldered for solid connection. New trailer lighting connection plug.
Don't miss the opportunity for a boat which has been carefully serviced for you to enjoy today! Credit card, cash or split payment of cash and credit accepted
162 Regency
Winter Haven
