Project Boat - 1988 Vanguard Bomber - GM 350 ci V-8, OMC Cobra out-drive, Hydraulic steering, Bass Pro XPS 4/4 2 bank onboard charging system, 2 live wells, center storage locker, classic trailer - single axle, new tires & rims has all original gauges + hook up for trolling motor, new upholstery 3 yrs. ago. This is a project boat! The floor needs replacing, the original engine 302 ci V-8 was replaced with the current 350 ci. The 350 was running when installed but has not run in the boat. Engine was out of a GMC pickup. It needs points, condenser, wiring harness. I have the headers which need to be put on the engine as well as an additional flywheel. The hull is in good shape as well as the stringers (only rot I have found is in the floor. Boat was last in water 3 yrs ago.
- Bomber
- $1000.00
- Smyrna
- Tennessee - TN
