EndPovertyNowInc
- May 2, 2025
Asking $9,000 for a 1984 Burns Craft 40 Sports Fisher Motor Yacht located at Corpus Christi Marina. Start your rental fleet or cruise the Gulf.
Incredible investment opportunity if you know something about car/boat repairs!
Priced to sell in 2 weeks. Call today to see it and make your best offer!! Don't miss this wholesale opportunity!
ACCOMMODATIONS
Sleep up to six guests comfortably in elegant quarters throughout the hull, including a private forward double berth. Enjoy relaxing in the bright and airy salon or gather around the cozy dinette for meals and conversation. The boat features a full head with a stainless steel sink, hot and cold pressurized water, and a stand-up shower. A generously sized galley is fully equipped to handle all your onboard cooking needs.
City Marina requests people only sleep on the yacht 15 days per month. Previous owner lived on the yacht. Slip rental 450/mo.
$400k new.
HULL No: BCI400040484-SF
Engines: Two 350 HP Crusaders, Model: CH 350, 8-cylinder gasoline, electric starting, fresh water cooled with heat exchanger, driving twin screws through Velvet Drive,
Model: 1018-010, 2.57:1 ratio reverse/reduction gears.
Engine intakes are bronze, seacocks are not equipped with wooden taper plugs.
DISPLACEMENT: 40,000 lbs.
ESTIMATED SPEED: 20 knots
FUEL CAPACITY: 420 US gals
TOTAL HORSEPOWER: approx. 700
POTABLE WATER CAPACITY: 120 US gals
Features a modified-V hull, solid fiberglass bottom, and balsa-cored hull sides.
The boat has a wide beam for a 40-footer (14'3") and a spacious interior with a full-size dinette, and double berths in each stateroom.
Repairs needed:
Port engine inboard exhaust riser needs replaced.
Yacht contains light scratches which are typical for the age and service.
Hardtop fiberglass repairs incomplete. Area is about 24" long.
Needs PFDs, Smoke and CO detectors and other minor repairs that can be done as you go along.
ENGINE EXHAUST SYSTEM
Wet type with reinforced rubber exhaust hose piping, fiberglass fittings and fiberglass mufflers. All piping exits through sides above waterline.
ENTERTAINMENT
FusionTM Model: MS-RA55 12VDC marine FM stereo player.
One, Hisense TM Model: Roku TV TM 120VAC TV with SonyTM Model: DVP-SR510H DVD player
and DISH Wally satellite antenna.
NAVIGATION LIMITS
Coastal waters of the Gulf of Mexico not to exceed 20 miles from land.
This limit may be extended by providing means of long range weather and safety communication
(i.e. Marine SSB radio, satellite communications system, offshore cellular telephone, etc.) or
other safety and lifesaving equipment such as a life raft or life float, and experienced crew and
proper preparation.
FUEL SYSTEM
Two independent aluminum tanks with shut-off valves at tanks.
CONTROLS
Manual type individual levers for throttle and reverse gear, two control stations. Located in bridge and cockpit.
VENTILATION SYSTEMNatural and mechanical type for engine room with two intake vents and two exhaust vents equipped with electric powered blowers.
Natural and mechanical type for personnel accommodations with forced draft circulation through air conditioning system, or through door, port light windows and vent openings.
STEERING SYSTEM
Hydraulic type wheel steering, two control stations.
AC SYSTEMS
240/120 volt power supply from dockside shore power with main switch panel,
distribution/breaker panel and plastic covered marine type wiring. Watertight marine type exterior fixtures and standard household type interior fixtures.
POTABLE WATER SYSTEM
One independent aluminum tank with plastic and hose piping, manifold, fittings, one, 19 gallon electric water heater and one electric powered pressure unit.
DECK FIXTURES AND GROUND TACKLE
Mooring Cleats & Lines: 10" mooring cleats located two forward, two amidships and two astern.
Double braided line
Anchors/Rodes: 20-lb. light weight type anchor with about 50 feet of 3/4" line rode.
Boarding Ladder: Folding type stowed in cockpit lazarette.
SAFETY EQUIPMENT
Red and green side lights properly screened; white bow light; white stern light; one white anchor light; one triple trumpet & pneumatic horn.
Contact us for more info!
Charity Owned. Proceeds benefit children & families in extreme poverty!
Estimate 5-10k in repairs while you sleep or party dockside. Then cruise the gulf and make money on GetMyBoat and BoatSetter (like airBNB for boats) $250/hr $500 minimum!
Perfect for preppers looking to have an escape hatch.
Great mental vacation and getaway project! Great side business opportunity flipping or renting it out ! Make your best offer - priced to sell fast!!
ACCOMMODATIONS
$400k new.
Repairs needed:
ENTERTAINMENT
NAVIGATION LIMITS
proper preparation.
FUEL SYSTEM
CONTROLS
STEERING SYSTEM
AC SYSTEMS
Double braided line
SAFETY EQUIPMENT
- Burns Craft
- Sports Fisher Motor Yacht
- $9000
- Corpus Christi
- Texas - TX
