- #1
- Ranger
- R72
- $9300
- Cincinnati
1994 Ranger Sport R72 (17'0") with 1994 Mercury 115hp two stroke outboard. This boat is in excellent condition for its age, it has been well cared for, garage kept, and all maintenance is up to date. It has a Motorguide X3 70# bow mounted 24 volt foot controlled trolling motor with 5 speeds and a recessed foot pedal pan in the casting deck. There is a Lowrance Elite 7 HDI color fish finder on a RAM mount at the casting deck with a trolling motor mounted transducer, and there is a Lowrance Elite 5 HDI color fish finder with GPS and Lake Map chip at the steering console. There are 2 full size rod lockers, dual aerated livewells, 2 dry storage compartments, 2 removable pedestal fishing seats, and a running rod ramp at the passenger console. The nav lights, bilge pumps, and aerators, interior lights, and gauges on the dash all work correctly. There is a NoCo Genius 3 bank battery charger that is less than 4 years old which charges all 3 batteries. The outboard runs perfect and is fuel efficient. It starts easily, idles quietly, shifts into fwd and reverse smooth, and pops up on plane immediately. The water pump impeller was changed in the fall of 2017 and the lower unit gear oil has been changed every fall. 1994 Ranger trailer tows perfect on the highway, the tires are less than 3 years old. There is a spare tire mounted on the frame, wheel bearings have always been kept greased, the brakes work, the lights work correctly, it has safety chains, and it uses a 2" hitch ball. Boat has always been garage kept and I have a cover for it. The best feature of this boat is that it fits in a single car garage. It fits through an 8ft wide door that the larger 18ft Rangers can't fit through. The rig is light so you don't need a full size truck to tow it, a small SUV, minivan, or V6 car should work. Will give test drive or let you have it inspected by a local marina. $9300. Boat is located in Cincinnati Ohio, worth the drive. Call or Text 5132843025 with Questions.
