2014 Tracker Pro Guide V175 Combo for Sale in Havre de Grace, Maryland
  • Thread starter Thread starter Moving North
2K Total Thread Views
Moving North
Used less than 100 hours
Mercury Marine – 115EXLPT (115 hp
Fuel Tank capacity – 21 gallons
Features
4 cleats
Horn
Fire extinguisher
Aft swim platform w/boarding ladder
Bow & stern eyes
Easy-fill EPA-compliant fuel tank
Drink holders
Paddle
Removable ski tow pylon
Safety lanyard
Flotation meets or exceeds NMMA & U.S. Coast Guard requirements
Console(s)
Black Metallic instrument & switch panel
Strategic instrumentation layout w/recessed gauges for reduced glare & easy visibility
Illuminated single-function gauges w/GPS-driven speedometer (w/direction indicator), tachometer, voltmeter, fuel gauge, water pressure & trim gauge
Lowrance Chirp fishfinder
Port & starboard fiberglass-reinforced molded console tops w/tempered safety-glass walk-thru windshield w/ lighting
Mercury control box
Toggle switches
Passenger console w/storage/cooler, drink holder & small items tray
Weather-protected AM/FM/CD stereo w/MP3 jack in passenger console
Padded sport steering wheel
72” removable running light
Construction & Exterior
Transom motor-mounting plate for increased strength & durability
Welded-in longitudinal stringer system for full-length support of the running surface
Extra-wide, all-welded, 2-piece .100 aluminum Deep V hull for a roomy deep interior, stability & predictable handling
Injected, expanding hull foam for extra hull stiffening, flotation & quiet-riding sound insulation
Reverse chine hull design for exceptional holeshots, steering response & turning
Tall 25" (63.50 cm) extruded box-beam, corner-braced 100%-welded aluminum transom
Heavy-duty 1-piece,extruded aluminum gunnels
Red & White graphics scheme w/Graphite painted gunnel & hull sides & natural aluminum bottom
All-composite seat frames for long-term durability & resistance to the elements
Pressure-treated floors & decks w/limited lifetime warranty
Flush-mount, all-aluminum carpeted compartment lids for structural rigidity, tight fit & long-term durability
Molded bow storage box w/raised lip for drier storage
Electrical
Abrasion-resistant wire-protective wrap
Bow & console courtesy lights
Bow panel w/trolling motor receptacle, 12V outlet & motor tilt switch
Port console-mounted 12V outlet
Stowable navigation lights
500 GPH (1,892.71 LPH) bilge pump
Interstate cranking (1) & trolling (1) batteries
Interior
6 pedestal seat base locations
2-3/8" (6.033 cm) swiveling & locking seat pedestals
TRACKER-exclusive VERSATRACK® accessory-mounting channel in gunnel
Elevated bow & aft fishing decks
Marine-grade, cut-pile carpeting on bow & aft decks
Marine-grade vinyl cockpit floor covering
Deluxe helm seat w/slide adjustment
2 movable fold-down swivel fishing seats w/pinchless hinges
Midship & aft battery storage
Bow padded backrests
Carpeted trolling motor deck w/drink holder
Removable bow-floor insert w/designated storage
2 extra-deep top-loading lockable boxes in the cockpit sides for rods/gear up to 8' (2.44 m)
In-floor rod storage for rods/gear to 7' (2.13 m)
2 aft fold-down jump seats w/port livewell & starboard storage below
Rod hold-down straps
Stern mounted Lowrance fishfinder
Livewell Systems
Aft (below port jumpseat) 11-gal. (41.64 L) aerated grey livewell w/timer & adjustable fill
Bow 19-gal (71.92 L) aerated grey livewell w/removable bait bucketâtimed & recirculated w/pump-out system
750 GPH (2,839.06 LPH) aerator/fill pump & 500 GPH (1,892.71 LPH) recirculating/pump-out pump (bow livewell)
500 GPH (1,892.71 LPH) aerator pump (for aft jump seat livewell)
Trailer
Factory-matched, color-coordinated drive-on trailer
All-welded tubular frame for a unitized structure w/an exceptional strength-to-weight ratio
Powder-coated steel w/GALVASHIELD® corrosion protection
EZ lube hubs for complete lubrication
Heavy-duty upright load guides for easy, centered loading
Folding tongue jack w/swivel wheel
Space-saving swing-away tongue
Heavy-duty winch w/nylon strap w/bow safety strap
Nylon tie-down straps
Carpeted bunks & fender boards
Outboard motor support
Retractable safety cables
Spare tire/tire rack
Submersible lights
Trolling Motor
Minn Kota PowerDrive 12V, 55-lb. thrust, 54" (1.37 m) shaft, foot-control trolling motor
Thru-bolted trolling motor mount
Tracker
$18,500
Havre de Grace
  • rpmsports
· BASS TRACKER PRO 175 14’ This boat is super... McQueeney,
rpmsports
Water N Wheels
  • Water N Wheels
· 2014 Godfrey Aqua Patio AP 250 WB Pontoon for... Fort Myers, Florida - FL 33919 · Price: $50000
Water N Wheels
Water N Wheels
· This item is being sold by ONLINE AUCTION on... Friday Harbor, Washington - WA 98250
· This item is being sold by ONLINE AUCTION on... Seminole, Florida - FL 33772
Water N Wheels
  • Water N Wheels
· 2014 Sea Ray Sundancer 310 For Sale in... Jacksonville, Florida - FL 32224 · Price: $178000
Water N Wheels
Water N Wheels
