30ft Pearson Sailboat
Ffeedom
1977 Pearson, “FREEDOM” Located kill Devil Hills North Carolina, good shape no soft spots Or blisters. The boat is a 1977 Pearson 30, 5ft draft, fixed inverted shark fin keel. Totally encapsulated [no keel bolts]. Rebuilt Atomic 4 25hp gas engine with fresh water cooling. Approx 60 hrs on engine. A 1988 main in good condition, a 2008 Pentex full battened main in near perfect condition, 155 Pentex genoa in very good condition[2005], 135 working jib in good condition, a 100 Mylar blade in poor condition, a spinnaker in poor condition, a jenaker in good condition, a whisker pole as well as a spinnaker pole. With all related hardware to set the spinnaker. Wheel steering with Navico autopilot,back-up tiller arm, Garmin GPS 2009, Jabsco head, Standard Horizon VHF with remote microphone, Martec 2 blade folding prop, with spare 3 blade prop, new cutlass bearing in spring of 2013, at which time the boat was hauled and cleaned, sanded, and a 5th coat of VC Offshore vinyl bottom paint applied. The boat was purchased in 2003 in Gloucester Va, where it was hauled and the bottom was stripped down to bare fiberglass, 6 coats of Interlux barrier coat and 2 coats of VC Offshore were applied. Since then, it has been hauled a total of three more times, each having sanded and another coat of VC Offshore applied. Minor blistering found each time[ less than 10 blisters total, the size of pencil erasers.] This last haul, no blisters were found. One 3yr old AGM battery, 2 2speed lewmar self tailing genoa winches, as well as 2 single speed spinnaker winches. The mast is decked stepped with a custom made deck plate underneath it to which all turning blocks are fastened. All lines led aft to cockpit. Two single speed winches on coach roof with multiple line clutches. The deck needs painting but no soft spots anywhere. The starboard port lite leaks and needs rebidding. The exterior teak needs refinishing and one teak piece on the port winch deck need replacing. the companion boards are split, cupped and needs replacing as well as the up right trim on the companionway. The new teak lumber needed to do the job goes with the boat. The blower motor needs new brushes, but I purchased a new blower motor that needs to be installed. Anchor, binoculars, drogue, bottom scrubber, 2 fire extinguishers, flare gun, multiple life jackets are all included. Flares are out of date. Boat needs hauling out and bottom clean and painted. The boat has seen little use since 2009 at which time I purchased a larger boat.
Pearson
30 ft sloop
$7500.
Kill Devil Hills
North Carolina - NC
· Enjoy the peace and serenity of sailing the... Harrison Township, Michigan - MI 48045 · Price: $6900
· Asking $6,900 for a 1975 Pearson Sailing Sloop... Harrison Township, Michigan - MI 48045 · Price: $6,900
· 26' Yamaha 9.9 4 stroke electric start. 2 deep... Flowery Branch, Georgia - GA 30542 · Price: $2000
· 1972 Pearson 30' sloop hull #149. Atomic... Marblehead, · Price: $3495.00
· 1974 Perason Perason 30SL Cousins Everett... Chula Vista, · Price: $4900
