- #1
If you are in the market for a bowrider, look no further than this 2015 Regal 2100 BR with power reclining tower, priced right at $44,950. This boat is located in Bradenton, Florida and is in great condition. Boat is also equipped with a Volvo Penta engine that has only 204 hours. With so many boats in the 21-foot class, it’s surprisingly difficult to find one with ample seating, storage and leg room. Enter the Regal 2100. With class leading seating and storage tucked within a sleek profile and FasTrac running surface, the 2100 pulls ahead of the pack literally and figuratively.
This boat has been recently serviced; oil change, spark plugs, fuel filter, serpentine belt and battery. Boat when not in use is stored in a high n dry. First 170 hours fresh water only; lake exclusively. Cockpit, bow cover, 3 anchors and boat trailer also included.
Cockpit
Nominal Length
· 21ft
Length Overall
· 21ft
Beam
· 8.5ft
Max Draft
· 2.83ft
Weights
Dry Weight
· 3,500Lb
Miscellaneous
Seating Capacity
10
Tanks
Fuel Tanks
· 40gal
Total Power
· 240hp
Engine Make
· Volvo Penta
Engine Model
· 4.3L V6-240 Dual prop
Engine Year
· 2015
Deck Gear
- Anchor
- Anchor Locker
- Anchor Rope
- Bimini
- Cleats
- Glove Box
- Rub Rails
- Ski Tow Eyes
- Swim Ladder
Electrical Systems
- 12 V DC Outlets
- Battery Switch
- Docking Lights
- Fuel Gauge
- Fuse Panel
- Hour Meter
- Oil Pressure Gauge
- Speedometer
- Stereo
- Tachometer
- Volt Meter
Mechanical Systems
- Bilge Blower
- Bilge Pump
- Engine Alarms
- Fuel Injected
- Power Trim & Tilt
- Throttle/shift: Elec
Navigational Equipment
- Navigation Lights
Safety Equipment
- Engine Kill Switch
Cockpit
- Bow Anchor Storage
- Cockpit Ergonomics
- Dual Bow Lounge Seats
- Fusion Marine Sound - 6 cockpit speakers
- Interior Appointments
- Removable Cooler
- Stainless Drink Holders
- Sunpad
- Trash Receptacle
- Center Line Walk-Thru
- Courtesy Blue LED Lights
- Fiberglass Cockpit Liner
- Gull Winged Transom Storage
- Custom Sea Deck flooring throughout
- RTM Hatches
- Stainless Hand Rails
- Swiveling Companion Seat
- Power folding tower with Bimini
- Composite Stringers
- FasTrac Hull Design
- Limited Lifetime Hull Warranty
- Navigation Lights
- Stainless Cleats
- Stainless Fuel Fitting
- Stainless Steel Bow Scuff Plate with Lifting Eye
- Transom Brake and Turn Lights
- Vinyl Ester Barrier Coating
- Electric Horn with Stainless Cover
- In-Mold Gelcoat Boot Stripe
- MarineTred Non-Skid
- Pop-up Stainless Ski Tow
- Stainless Deck Hardware
- Stainless Rub Rail
- Telescoping Boarding Ladder
- Transom Trim Switch
Nominal Length
· 21ft
Length Overall
· 21ft
Beam
· 8.5ft
Max Draft
· 2.83ft
Weights
Dry Weight
· 3,500Lb
Miscellaneous
Seating Capacity
10
Tanks
Fuel Tanks
· 40gal
Total Power
· 240hp
Engine Make
· Volvo Penta
Engine Model
Engine Year
· 2015
Deck Gear
- Anchor
- Anchor Locker
- Anchor Rope
- Bimini
- Cleats
- Glove Box
- Rub Rails
- Ski Tow Eyes
- Swim Ladder
Electrical Systems
- 12 V DC Outlets
- Battery Switch
- Docking Lights
- Fuel Gauge
- Fuse Panel
- Hour Meter
- Speedometer
- Stereo
- Tachometer
- Volt Meter
Mechanical Systems
- Bilge Blower
- Bilge Pump
- Engine Alarms
- Fuel Injected
- Power Trim & Tilt
- Navigation Lights
Safety Equipment
- Regal
- 2100 BR
- $42,950.00
- Bradenton
- Florida - FL
